Data XML export
Forum issues, bug reports and suggestions
ChristianVirtual
Re: Data XML export
Post by ChristianVirtual »
Can not thank you enough for your responsiveness and support ! outstanding ! :D
Is that sprint file also every two hours or every hour like the update on the web site ?
Any direct message might be subject of publication; sender's consent assumed
ChristianVirtual
Re: Data XML export
Would it be possible to set the update frequency to one hour for the export of the stats via XML files ? :jap:
sebastien
Fondateur et patron suprême
Re: Data XML export
Post by sebastien »
Done.
XML files will be updated each hour following sprint stats update.
