QCN
Posts about the 2017 season of Formula BOINC - this section locked
Locked
Coleslaw
QCN
Post by Coleslaw »
It looks like the recent stats screw up by QCN has caused it to drop off the FB lists. Is there any way of retaining the scoring? I doubt we have enough time left in the year to get it to re-qualify.
Pit
Re: QCN
Post by Pit »
I totally agree to Coleslaw.
Project is stil alive, but somehow droped out of the charts.
Can someone from Orgteam please take a look and fix the problem?
Thanks / Merci bien
Coleslaw
Re: QCN
Post by Coleslaw »
The problem is that the project had an issue and restored points from an older backup. The admin has not chimed in on details. So, all the stats sites pulling the latest stats export are reporting as if none of the points for the last year ever happened. So, if Sebastien has an old export to base things off of, he could restore team positions. If he does not, there may not be anything he can do.
fax
Registered FB member 2023
Re: QCN
Post by fax »
That project has been unmaintained for quite a while already and should simply be removed.
Locked
